T-5 not going into gear
Old Feb 6, 2005 | 12:43 AM
Thirdgenz's Avatar
Car: 87 GTA
Engine: L98 5.7 TPI
my trans will not go into gear unless the shifter gets a foot behind it. any clues??
Old Feb 6, 2005 | 11:54 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Re: T-5 not going into gear
---Clutch not disengaging fully? Check fluid level. Bleed clutch system. If you have a leak, replace everything as a unit. You can get the master cylinder and slave cylinder together already bled.
---Bent clutch fork? Replace it.
---Frozen/seized throw-out bearing? Pull trans and replace it.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
georgiaslim45
Sep 9, 2015 08:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
