need help with t-56 speedo wiring!
Old Feb 9, 2005 | 03:43 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
I recently swapped a t-56 into my firebird. It has a mechanical speedo but I'm ditching that and going with this:
http://www.nordskogperformance.net/p...tail/m9222.htm
I don't have the wiring harnesses for my trans. Do I need to get this first? Where does the speedo wiring hook up to the tranny???
Old Feb 9, 2005 | 04:37 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The VSS is at the left rear of the transmission sticking out of the tailhousing. Yes, you need that wiring connector.
Old Feb 9, 2005 | 09:16 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I have a similar queston, what dose the t56's speedo wires get hooked up to, I am going to use Nordskog's digital dash, p/n DP4004, and I know one wire goes to it, but which wire, and where to the other ones(not sure how many total it has...)go to?
discription:
http://www.nordskogperformance.net/p...003-dp4005.htm
manual:
http://www.nordskogperformance.net/t...els/DP4004.pdf
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
cRoe4
Aug 7, 2015 08:46 PM
beachrodder
Aug 7, 2015 04:27 PM
