Tranny Grinding into First and Reverse...dont want to force
Old Feb 18, 2005 | 01:53 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
I know this isnt camaro related but i have an 89 gmc 5-speed that i just installed a new hydraulic clutch into. It grinds when trying to put it in first or reverse and tries to jump forward and move when started in first even with the clutch depressed to the floor. I was just wandering what this could be?? Any suggestions would be helpful
Old Feb 18, 2005 | 02:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=278013 Scroll down a bit. Does what's in those pics look familiar?
Old Feb 18, 2005 | 02:04 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
I had one of my friends put it in for me...dont know that much about it...so exactly what is it and what is your suggestion??
Old Feb 18, 2005 | 02:10 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
ok so its something with the throw out bearing i cant really tell what they were saying about being inside or outside....
Old Feb 18, 2005 | 04:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at the little ears on the flat spring, where the fork attaches to the throwout bearing.
The throwout has a groove about 3/16" wide, that the fork slides into. Those ears belong INSIDE that groove along with the fork, compressed into the "cavity" of the fork. It's real easy when putting it together, to get the ears sort of "clipped" onto the outside of the groove, like the top pic. That will cause the clutch to fail to release. You'll have stiff shifting, crashing into gears especially reverse, and so on; basically, exactly what you've got.
Old Feb 19, 2005 | 10:46 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Yup, I agree - throwout bearing installed incorrectly to fork. Did it myself once and had the problems you described.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
