91 camaro rs 305 TBI gear ratio
Old Feb 18, 2005 | 02:35 PM
mjmaro91's Avatar
thinking abotu putting a positraction unit into my car but there is no way to tell the gear ratio without opening up the housing. does anyone know the stock gear ratio for a 91 camaro rs with the 305 v8? i called idfferent dealerships in my area and they couldnt help me using the vin number. i know it is either a 2 or 3 series ratio but i need to know which. the posi will only work with a 3 series ratio, thanks
Old Feb 18, 2005 | 04:06 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
IF its original
Auto tranny=2.73
5 speed=3.08
Old Feb 20, 2005 | 11:07 AM
mjmaro91's Avatar
thank you sooooooo much, now i need a gear conversion kit to get the posi in, but it will be worth it
Old Feb 20, 2005 | 09:37 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You just need a 3 series carrier and 3 series gear. That is not the only way but may be the cheapest. 3 series carriers and gears out of a 4th gen would be a good starting point. If you don't trust used parts you can always buy new gears from many different companies that will for your rear. Gear swaps and a posi are great for any 3rd gen car, even if it is a 305 TBI
Old Feb 20, 2005 | 10:26 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
the thing is you can use 3-series gears (ring and pinion) with a 2-series carrier because the carrier is smaller than the ring gear and an adapter/spacer plate will make it work. you cannot use a 3 series carrier with a 2-series ring gear because the ring gear is too small to fit over the carrier. also remember that some housings that came with 2-series gear and carrier might be too small to fit in the 3-series ring or carrier. and make sure to have your new ring pressed onto the carrier housing, don't just try and pull it up with the screws like i heard of someone else doing before...
Old Feb 21, 2005 | 12:45 AM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
i have a 91 305 tbi 5 speed and i recently installed a powertrax diff locker, actually called the "No-Slip Traction System". works pretty good, im happy with it. not terribly expensive and it took about 30 mins to install. it definatly got me threw the snow this winter.
just a FYI
pimp2303
Jul 27, 2017 02:03 PM
hectre13
Aug 26, 2015 08:17 AM
MENINBLK
Aug 5, 2015 11:58 PM
