what size gears do i buy..
Old Feb 20, 2005 | 11:14 AM
souperman28's Avatar
Car: 89 IROC-Z
If i have a 89 Iroc is it the 7 1/2 or is it bigger? i dont want to buy the wrong 3:73's thanks.
Old Feb 20, 2005 | 11:27 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
you will also have to get a 3 series carrier for the 3.73s.
Old Feb 20, 2005 | 11:32 AM
Car: 89 IROC-Z
what do you mean, where do i buy that?
Old Feb 20, 2005 | 11:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Do you have a 9-bolt, or a 10-bolt?
What gears are in it now?
Old Feb 20, 2005 | 11:55 AM
Car: 89 IROC-Z
i have the 10 bolt with i think the 2:73's i thnk
Old Feb 20, 2005 | 12:13 PM
White91GTA's Avatar
Engine: 5.7L TPI
The differential is called the carrier. So you will have to get a 3 series posi unit (differential)
Old Feb 20, 2005 | 12:34 PM
Car: 89 IROC-Z
so that is madatory when you put in the new gears?
Old Feb 20, 2005 | 12:42 PM
White91GTA's Avatar
Engine: 5.7L TPI
3.08 and numerically lower are a 2 series
3.23 and numerically higher are 3 series
so going from the 2.73 to 3.73 you will need the 3 series
Old Feb 20, 2005 | 12:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Also the 7-1/2" and 7-5/8" are interchangable. They use the same carrier but as mentioned above, you'll need a 3 series carrier (posi) to swap to 3.73 gears because your current 2.73 gears are on a 2 series carrier.
There's also a very good chance your 1989 carrier is only 26 spline. Only a handfull in 1989 were 28 spline. They'll need to know that when you buy a new carrier. The only way to know for sure is to pull an axle and count the splines.
Old Feb 20, 2005 | 01:03 PM
ede's Avatar
ede
you can also use a shim or gears made to work on a 2 series carrier
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
