what kind of posi unit is this???
Old Feb 20, 2005 | 02:14 PM
matt84z28's Avatar
Car: 1984 Camaro Z28
Engine: Turbo V6
Transmission: 200r4
I know it for a 3rd gen fbody but don't know what type i think its from gm cause a guy that used to work at a chevy dealer gave it to me....thanks
Old Feb 20, 2005 | 03:09 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
that would be a goveror style limited slip unit. what size rear is it for?
Old Feb 20, 2005 | 03:15 PM
matt84z28's Avatar
Engine: Turbo V6
Transmission: 200r4
for the 7.5
Old Feb 20, 2005 | 03:16 PM
matt84z28's Avatar
Engine: Turbo V6
Transmission: 200r4
it came brand new in box little surface rust thought, Is it a good unit??
Old Feb 20, 2005 | 03:17 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
i'm not quite sure that is out of a third gen. all of them used the spring/clutchpack design. it may be out of a fourth gen.
Old Feb 20, 2005 | 10:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's probably out of a S truck, although a few of them found their way into these cars in the early years of their existence. That's the dreaded useless POS known as the Eaton Grenade-Lock (Gov-Lock according to its mfr).
It acts like an open diff, i.e. no clutching action whatsoever, until the difference between the RPMs of the 2 axles exceeds about 100 RPM. At that point it attempts to lock up. Which means, no posi action whatsoever from a stop.
Obviously, quite good for a 4WD type situation, in mud or something, where there's no traction; but a VERY VERY BAD design for pavement. It WILL turn itself to shrapnel if used in a high-power application on asphalt or concrete. Even a 6-cyl like the ones in S trucks will grenade them easily.
DO NOT buy it thinking it's going to give you better traction off the line.
Old Feb 20, 2005 | 10:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
And that looks like a 2 series one besides.
Like most "free" things, there's a reason it's free.... namely, it isn't worth anything to anybody.
Old Feb 20, 2005 | 10:29 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
yea i've heard many people with limited slip in their s-10s complain about spinning one tire while powerbraking, guess this is why. glad i went with an auburn pro
Old Feb 20, 2005 | 10:32 PM
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
and try scrubbing it with a toothbursh and some gear lube, the surface rust should come off and the gear lube will sink into the poruous carrier and you won't have to worry about it. when i cleaned off my old open carrier with brake clean and then soappy water it got surface rust with in 5 minutes. scrubbed it down with a toothbrush and gear lube and it looks like new
Old Feb 20, 2005 | 11:02 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
i also have my old posi unit if anybody wants it. it has no rust on it though
Old Feb 23, 2005 | 10:25 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I'll take it
Old Feb 23, 2005 | 11:04 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Originally posted by 84L69TA
I'll take it
i had it posted in the classifieds. nobody bit there. i have a local guy that wants it. if he doen't have the money tomorow, i will let you know. $125 includes posi and 3.23's with 40K miles.
Old Feb 23, 2005 | 11:31 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
My old Z28 had one, dident last too long. I havent bothered to see if my new Z28 even has posi. Shame on me.
Clean it up Ebay it in the box and get one that will last more then a couple burn outs.
djmarch
Sep 13, 2015 01:35 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
