Tranny Issue....Need Help
Old Feb 22, 2005 | 06:19 PM
snyperz28's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8 V6 (soon to be 350)
I have a 1984 Camaro with 305 LG4 a 700R4 tranny. The car needs a tuneup and it idles at 850K (I know thats high). I know that I need a new shift cable bracket as mine is bent and the cable wiggles a lot. I have an issue with it also slipping out of park into reverse because of this.
However my issue is that when I do put it in drive or reverse from park it makes a loud and noticeable clunk when it goes into gear.
1) Could this be just the shift cable
2) Is it a tranny issue
3) Is it a driveshaft issue
4) Idle issue
When driving the car shifts perfectly, only at idle does it clunk.
Old Feb 26, 2005 | 11:31 AM
Vader's Avatar
...Or axle issue, or the trans mount, or a torque arm mounting. Or something else. You're going to have to get under thare and take a look to be certain.
Old Feb 26, 2005 | 12:02 PM
Pheonix542's Avatar
Car: '83 Trans Am
Engine: Carbed 350 290hp 350ft/lbs
Transmission: wore out T-5
it might be the u joint...
i had that problem around 280k miles
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
