700r4 problems....time for rebuild?
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Had my tranny rebuilt 60k miles ago because of late shifting. Sometimes I could barely get out of 1st or 2nd gear. Now its starting to have the same problems.
Is 60K mi good for a rebuild?
I'm having a rebuilt engine put in this week, and i think i'm just going to have them rebuild my trans at the same time.
well i figured the machine shop could pull the tranny at the same time as the engine and take a look. I guess that would be the easiest thing
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I would pull the governor form the side of the tranny. And see if thats stuck. Cheap fix if thats the problem.
I'll look into that...thanks. Would it make a difference if i also added that when it does feel like its slipping, its usually after i've been driving around for a while and the tranny gets warm (like after long trips).
Could it still be a stuck governor then also?
Sorry...i wish i knew more about transmissions.
3.8TransAM
Sep 27, 2015 08:37 PM
Dragonsys
Sep 25, 2015 03:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
