HELP!!!!! th350 swap question.
Old Feb 28, 2005 | 02:59 AM
davey's Avatar
Car: '95 cutlass supreme, '82 F-150
Engine: 3100, 302
Transmission: auto
I just ordered a th350 swap kit made by hurst to finish up an already started project. can anyone tell me if I need anything not included in this kit. I don't have the old 700r4 and need to know if I need to buy anything else to finish this up.
here's a link to what i bought:
http://www.jegs.com/cgi-bin/ncommerc...60&prmenbr=361
please help, i have never done this and am asking all the experts to give me a hand.
Old Feb 28, 2005 | 04:45 AM
CrazyHawaiian's Avatar
Car: too many ...
I used the same kit for my car. Also needed a crossmember, a dipstick tube, a kickdown cable, and a drill to modify the Hurst Bracket to accept my torque arm bushing bracket. Apparently Hurst did not know there were 3 different types of torque arm brackets used on our cars throughout the years, so it only fits one style. I was able to re-use the stock 700R4 driveshaft since I had a longtail TH350, and the cooling lines need to be bent to fit, make sure not to kink them. Cheapest crossmember is one from a early model F-Body with the 200R4 tranny at the yard, but I couldnt find one in time, so I bought a Spohn one. I got the dipstick and kickdown through Lokar, though there are probably cheaper ones out there.
Old Feb 28, 2005 | 11:44 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I might have gotten lucky when I purchased my Hurst unit off E-bay. When I got the parts it had a bracket that bolted to the original tranny mount location and offset the crossmember mounting point so I was able to retain the factory 700r4 crossmember that I had in the car. I also used the 9" tailshaft so it all bolted back together with minor tweaking to the original tranny cooler lines.
Other than that crazyhawaiin parts list for the other stuff is right on. It's really a quick swap, it was actually the easiest and quickest tranny swap I've ever dont in my life(2hrs and I was on the road). A little advise I give to others doing this swap, I cut the outter ears off that the dust cover would bolt to if your were going to use it, this offered alot more clearance in the tunnel.
Old Feb 28, 2005 | 01:22 PM
davey's Avatar
Engine: 3100, 302
Transmission: auto
thanks alot guys, I really appreciate it. I really want to get this done. If you could see how rigged this thing is, you'd freak. The cross member is ran diagonally, exhaust clamps are holding the tourqe arm to the trans, and there's washers spacing the tranny mount. I bought the car like that and didn't notice until the speedo cable fell out and caused a fliud leak. I might take some pics and post them. Thanks again.
*** got it in and all assembled tonight, it works alot better. thanks for all the help guys.
RedLeader289
Jan 22, 2016 03:05 PM
LittleFranks
Sep 17, 2015 12:22 PM
downsouthboy
Aug 29, 2015 11:29 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Bryan F
Aug 18, 2015 02:28 PM
