HELP! tooth count on 3.45 BW gears...
Old Feb 28, 2005 | 02:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i can pick up a ring gear for 3.45 9bolt rear. but it has no pinion gear
i need to know if a 3.27 pinion will work with the 3.45 gear... i believe 3.27's are 36 tooth ring, and 11 tooth pinion. that comes out to 3.27 so if a 3.45 ring gear is 38 teeth it should work right?
38/11 makes 3.45
Old Feb 28, 2005 | 02:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. It will absolutely not work. There's more to a pinion gear than just the tooth count; the diameter is different for example. Same for the ring... they're different thicknesses, to make up for the different pinion gear diameters.
Your arithmetic is correct though, as far as it goes.
Old Feb 28, 2005 | 05:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
dang, i was hoping for it to work
i want 3.45 gears soooo bad
any ideas where to find a pinion for it???
Old Feb 28, 2005 | 08:20 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
they are a matched set anyway,
Old Mar 1, 2005 | 07:22 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Gear & pinions are sold ONLY as matched sets.
Old Mar 1, 2005 | 04:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah i know that....
i have been searching for 9-bolt stuff for a while and havent found anything. except the stuff at 9bolt.com and a few gear vendors. might have to invest in a 10bolt LS1 rear sometime.
cheesehomer
Dec 31, 2015 08:48 AM
gord327
Oct 3, 2015 01:25 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
6speedIROC
Sep 13, 2015 01:29 PM
