Torque arm bracket, already searched
Old Mar 1, 2005 | 10:43 PM
RacerDonnie13's Avatar
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
I installed the TH-350 in my car a couple weeks ago and used the B&M changeover kit. The car didnt have a tranny in it when i bought it so I went to the local junkyard and picked up the outer torque arm bracket. I also ordered the bushing from summit (part#ENS-3-111G) When i went to install the bushing and outer bracket of course it didnt line up. The outer bracket that I have lines up in the top groove closest to the motor perfect but only like 1/4 of the torque arm is inside the bushing, and the outer bracket doesnt contour to the bushing properly. Now on the box that the B&M kit came in it has a sticker on the outside that says i need to go to GM and get PART#******** ,or PART#********. Is that the outer bracket or is that the bushing? The bracket that I have has two bolt holes side by side in the bottom and the ones in the pics in the instructions only has one.I hear there are 3 different types of these brackets does anyone have a pic of all 3? Someone please help!!!
Old Mar 2, 2005 | 07:40 PM
brutalform's Avatar
Is it a poly bushing? There are 2 different bushings. One has the torque arm lips facing the trans, while the other one is facing away. Is this what you are talking about? You can just switch out the bushing if so.
deracer
Apr 11, 2016 12:04 AM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
