Rear Axle RPO
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The first year for the "SPID label" with all the RPO codes was 1984. If you are lucky you will find the build sheet under a seat cushion or the carpet. Another route would be to obtain the billing invoice from Pontiac Historical Services.
If you crawl under the car and read the axle code that's stamped onto the passenger side axle tube that will also tell you what you have.
hectre13
Dec 11, 2023 08:14 AM
