gears
Old Mar 3, 2005 | 05:15 PM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
gears
i am putting in a 355 with near 400 hp currently have 273 gears even though its a new engine i am changing the cam to a comp 268 extreme energy.i have a 88 iroc with 29 inch in the rear and a 700r4 i want opions on 342s or 373s?im not going to beat on it i just want the rps to match the cam which is 1600-5800
Old Mar 3, 2005 | 06:58 PM
sellmanb's Avatar
Car: '86 Berlinetta
Welcome to the boards. I might suggest checking out the other forum boards and posting in the proper one in order to get the best responses.
While I cant do the math in my head to figure out what RPM you'll be at w/ what width tires, your rear gear ratio, drive gear ratio, etc... I can tell you that the higher you go the easier your car gets winded, but at the same time, the faster it'll go down the track.
Is this for a street/strip car? Or just a daily driver? If a daily driver then a 3.43 gear ratio would probably suffice for you.
If you have a 9 or 10 bolt, you'll have a series 2 carrier, you'll need to upgrade to a 3 series carrier so that you can put the 3.x gears in there....
while you upgrade, you might as well buy a posi unit.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
