What rpms would 3.73's and 3.42's put me at 75mph?
Old Mar 4, 2005 | 12:23 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
At 70mph I'm cruising at 1900rpms with the 2.73's. What would I be doing with 3.73's or 3.42's. I have an automatic car.
Old Mar 4, 2005 | 01:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
my T5 in 5th gear on the highway, around 65mph, does about 2500 rpm. I have 3.73 gears.
Old Mar 4, 2005 | 03:34 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I do 70mph @2500rpms
Old Mar 4, 2005 | 05:27 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
If you know your Final gear in you Auto tranny use this:
https://www.thirdgen.org/newdesign/t...ulations.shtml
Old Mar 4, 2005 | 07:56 PM
colonboy14's Avatar
Car: Trans Am
A little less than 2000 at 80.
You guys need 6 gears.
Old Mar 5, 2005 | 12:43 PM
Car: 1994 Trans Am
So I'll be at 2500rpms at 70mph with 3.73's? So with 3.42's I should be around 22-2300?
Old Mar 5, 2005 | 01:11 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Don't forget you need to factor in your tire size, try this:
http://smokemup.com/auto_math/mph_range2.php
Old Mar 6, 2005 | 09:35 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I wish I had 6 gears, I am at 3000 at 85mph.
Old Mar 8, 2005 | 12:49 AM
SchwarzCamaroRS's Avatar
mine is pretty bad now too, i need a 6 speed... 3.23 gears with the 700R4 sucks... 3rd gear tops out right around 100mph
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Dec 11, 2023 08:14 AM
novaderrik
Aug 10, 2015 12:44 PM
