Is this stall converter stock?
Old Mar 5, 2005 | 12:27 PM
zapo's Avatar
Car: 88 Mustang
Engine: 7.7L (473 ci) EFI
Transmission: C6 3 speed auto.
88 camaro with a mild TPI 350, 212/212 @ .050 flat tappet cam and flat tops, hedmen full lengths and 3.5" single exhaust. The rest of car is stock including the 2.77 rear gears. Before the car came to me the 700R4 was replaced with what I was told was just a stock Replacement.
Do 700R4's have a loose converter stock? I can foot brake 2400 RPM outa this thing in my shop without even breaking a sweat. Is this normal for a stock 700R4.
My guess someone put a Corvette or 4.3L S10 stall in this thing when the trans was out, what ya think??
Old Mar 6, 2005 | 11:37 PM
zapo's Avatar
Car: 88 Mustang
Is there anybody out there with a stock 700R4 and TPI 350?
Would you please step on both pedals and read the RPM gauge. Is 2400 RPM flash stall stock?
Old Mar 6, 2005 | 11:43 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
My stock torque converter is super tight, the most i can get out of it standing on the brakes is 1200.
Old Mar 7, 2005 | 12:14 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my stock converter would stall around 900 and my corvette one stalled around 1800. this was behind a moderatly built 305 though.
Old Mar 7, 2005 | 07:52 AM
bcp19's Avatar
Car: 1985 TA
Engine: L69 305 H.O.
I've got a 92 Z28 with the 350TPI/700R4 and if I hit the brake and the gas at the same time, it'll go to around 1500 rpm, but the rear tires have a tendency to break loose and spin if I do this. (I figured if I said 5000rpm you'd raise the BS flag on me
Old Mar 7, 2005 | 10:27 AM
zapo's Avatar
Car: 88 Mustang
Thank you
Thank's I shall not order a stall for this unit then, it seems that it has one. And with a mostly stock TPI 350 I would think 2400 RPM is just right.
Old Mar 7, 2005 | 11:55 AM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Old Mar 8, 2005 | 01:21 AM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
Originally posted by GTA matt
so, wtf happened to the :werd: smiley? it was way better, this is
also, i have a stock 305 and 700r4 and it only goes to about 1500 before it starts to spin, if that helps any.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
