i hate my clutch linkage!
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
guess what people,my mechanical clutch linkage broke again,the shaft that links the pedal to the z-bar broke at the pivot point,so my question would be if anyone can tell me if this part can be obtained new from chevrolet? i tried searching for a part number to no luck,and the internet did not help either,so please help me
thanks in advance
thanks in advance Senior Member
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
It can be a PITA that's for sure. The last time I ha dmine out of the car I welded up the holes in th eends of the Z-bar and then redrilled them. I also reinforced the welds where the tube is welded tot he flat pieces. I then replaced the clutch forek and went under the dash. I welded up the wanged out hole in the pedal assy and replaced the linkage rods. You can also make up rods with heim joints fi you want to get real artsy-fartsy.
Anyway, I've had ZERO problems since.
Car: 83Z28 HO
Transmission: G Force 5 speed
Car: 83 Z28
Back in the day, Year One, same place you could still buy the complete L69 cold air stuff until some dirtbag bought out their entire stock.
http://www.yearone.com/
Car: 4
Engine: 6
Transmission: 5
Or, you could do what I did; I just swapped in the whole hydraulic system, back in about 86 or so, when I got sick of my 83's Z-bar crap after it got sticky again about 2 days after I greased it. I had hated those damn things for all the years I had been driving 3-speeds and 4-speeds in the cars I had before that, and that POS just pushed me over the edge one day, and I saw a car in the boneyard that had it; I scored it, slapped it off in there, and haven't regretted it for a minute ever since. Well, at least, until I put a T-56 in the car last summer; which is of course also hydraulic.
Car: 83Z28 HO
Until I find one, I'm just working with what I have.
blacksheep-1: Thanks for the info on the clutch fork!
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
Clutch Z-BAR
I got a new one at the local Chevy Dealer 5 or 6 months ago. I think it was around a 140.00 or so. The Paddock in Indiana sells them but they are on back order for some dumb reason so I got it at the dealer instead. Mine works fine now. I loaded it up good with grease and replace both pivot ***** and the felt seals which the dealer supplied too.
If you want to go with a hydraulic clutch let me know how much you will take for your bell housing that you have now. If the price is right I will take it off yours hands if there is nothing wrong with it.
first let me thank you all for your ideas and suggestions,i was told that there's a camaro in a junkyard that has all the h.system.so im goig to see how much they want for it,oh,and if i get the chance to convert it to hyd.i surely would sell everything to anybody interested.thanks
Car: `86 SS / `87 SS
Originally posted by Confuzed1
Say, I'd like to put a new clutch fork in mine. Where'd you get yours?
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
Lakewood make the bellhousing with the mount for the slave cylinder I'm doing the swap as i write found a junked bellhouising for $80 with the cover for the nose of the starter broken off so i cut it off my non hyd. bellhousing and put it on
