What is the weak point in the 700?
Old Mar 8, 2005 | 01:17 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I have my tranny apart to do a rebuild and figured this might be a good time to replace any parts that are especially prone to breaking.
I know anything will break if you have enough HP, but what is usually the 1st thing to usually break with say 350HP/400lbft? Or don't you need to worry with only 350HP?
Old Mar 8, 2005 | 07:26 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
There are only a few weak links in a 700 when you start pshing the hp limit. here they are in the order of weakness, at least from my experience.
1. Get a hardened sunshell. TCI makes one called the Beast.
2. get a kit that increases the number of clutches in the third gear clutch pack.
3. Stronger 2nd/4th gear band.
4. While not absolutely necessary, it wouldn't be a bad idea to replace the 4 pinion carrier with a 5 pinion carrier.
of course you do all this in conjuction with a transpack and vette servo.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
lanceflame44
Sep 25, 2015 12:28 PM
