How hard is it?
Old Mar 8, 2005 | 02:01 PM
My91RSCamaro's Avatar
Car: 1991 Camaro.
Engine: 305 TBI
How hard is it?
I just put in 3.73`s and a posi
Now i need to get my speedo fixed. Thanks to many of previous posts on the forum I fornd bowtieoverdrives.com They said I need Drive gear-15t, and Driven gear-43t.
My question is how hard is it to change the dears?????? give me some info guys.
Old Mar 8, 2005 | 05:13 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Changing the speedo gears is a snap.
1. Remove driveshaft
2. remove torque arm
3. remove speedo driven gear housing
4. remove tailshaft
5. you will need to pry the metal clip holding the drive gear to the tailshaft and slide the gear off.
6. Slide the new gear onto the tailshaft. Make sure it is aligned correctly before you slide it down. it is useful to tap it on with a pipe that fits over the tailshaft to keep it straight.
7. reinstall the tailshaft housing. Make sure you have a new o-ring.
8. Reinstall the driven gear housing with a new o-ring as well.
9. reinstall torque arm/ driveshaft, ect.
GM high tech performance had an article on this a few months back.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
