long time to downshift/automatic trans
Old Mar 9, 2005 | 07:23 PM
virtigo8776's Avatar
Car: 85 trans am
Engine: 383
Transmission: 700
not sure if this is the right board but didnt know where else i would put it
i have an 85 trans am with a non cc carb 383 700r4 trans. ever since i switched to non cc it has alot of lag when down shifting. actually the harder i press on the gas the worse the shifting is. the speed shops say it sounds lt sounds like a trans problem but it has a new trans in it and the old one did the same thing. also i do have the lockout torque converter kit for non cc cars on it(not the one with the button where you can lock out manually though). also i have an edlebrock performer intake with a 1 inch spacer on top(was getting vapor lock with out the spacer) so the gas peddle is alot heavier but even before the spacer the shifting was the same. just wondering if anyone has any ideas what i could look at to try to get the shifting back to normall. also i have had it dyno tuned so timing shouldnt be a problem
Old Mar 9, 2005 | 09:39 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like the TV cable either isnt adjusted properly or the geometry is off. Yes, either of these will kill the trans in short order. I found out the hard way.
Also, you can wire up a lockup switch in place of the ecm to lock the converter. The ecm basically just provides a ground path for the solenoid, thereby inducing lockup. In the ATSG, there are schematics for the wiring for the TCC solenoid circuits for various years. Those should give you some idea of what you have to do. There are kits available as well to restore automatic lockup.
Old Mar 10, 2005 | 01:37 PM
Car: 85 trans am
Engine: 383
Transmission: 700
thx for the help. took it in to have tv cable checked and they said it was fine though
Old May 10, 2006 | 06:51 PM
slipshift's Avatar
Car: 1986 trans am
Engine: 350 600 edelbrock
Transmission: 700 r4
tv cable adjust on 700 r4 non cc
How do you do this ??
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
