down shift
Old Mar 13, 2005 | 09:15 PM
coincounters's Avatar
Car: 1984 z28 ho
Engine: L69
Transmission: 700-r4
down shift
my 700-r4 doesnt want to down shift from 4 to 3 until i go less than 25 mph. a real pain when i do most of my driving at 40 mph. is this normal or not. please help with any info on this subject, thanks.
Old Mar 13, 2005 | 10:30 PM
Bombero's Avatar
Car: 1986 IROC T-Topz Black/Black w/Gold Decals/Rims & Badges
Engine: 305 TPI stock
I was wondering the same thing anout mine and found this in the tech articles:
Q: Why won't my automatic tranny shift into overdrive at wide open throttle?
A: It's designed not to shift into overdrive if your foot is all the way to the floor. You must be at 2/3 throttle or less before the tranny shifts into OD. So when you hit the top of 3rd gear, you'll have to let off the gas to allow for the shift. But putting your foot back into it will probably cause a downshift resulting in the same problem.
B and M makes a kit modified kickdown valve (part # 70237) which fixes this problem. It costs about $30 and can be ordered through the Summit or Jegs. GM also makes a modified upshift valve which it included in police packages and that part # is 8673948 and sells for around $15. This will allow the tranny to shift into OD at full throttle.
Now im wondering is this something I can do myself, like is it a part on the outside of the transmission, or do i have to get a shop go inside and install it?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
