T5 and T56 flywheels interchangable?
Car: too many ...
I tried a search but couldnt find a solid answer. Does anyone know if the flywheel used on a L98/T5 combo would also work with a L98/T56 combo? Parts in question are '89 L98 (3rd gen), '91 L98 (3rd gen), T5 (3rd gen) and T56 (LT1 4th gen). Both setups would use a 1 piece rear main seal, 153 tooth, neutral balanced flywheel right? So if you had an aftermarket flywheel it would work for both setups? If anyone can verify I'd really appreciate it. Thanks!!!
Car: 4
Engine: 6
Transmission: 5
Yes I can verify.
No they are not the same; at least not for a factory LT1 setup. The T-56 flywheel locates the clutch disc surface about ½" farther away from the engine than earlier ones such as T-5 or 4-speed ones.
So no, your T-5 flywheel WILL NOT work in the combo you have listed. You need the stock LT1 flywheel, or equivalent aftermarket unit.
Car: 4
Engine: 6
Transmission: 5
I ran across a pic of a T-56 one. This is the one for putting a stock LT1 T-56 behind a 2-piece rear main seal motor. Note the thickness compared to your T-5 one.
Car: too many ...
Thanks for the info RB!!! Darn it looks like my plan wont work. I was hoping to buy an aluminum flywheel for my current T56 swap into my 91Z28 (94 T56 mated to 91 Z28 L98), and then later on when I swap the motor in the 91 to a 2 piece RMS setup, I wanted to transfer that aluminum flywheel over to my 89 IROC (w/ stock L98 and soon to be TKOPerformance T5).
So the L98's from 3rd gens are 1 piece RMS or 2 piece? Sorry for the retarded question ...
And again ... really appreciate the help.
Engine: 383 carbed sb
Transmission: th350
Car: `86 SS / `87 SS
Originally posted by Igor
Where did you find this? what brand? I would like to find one for a 400 sbc to work with my lt1 t56. thanks.
Car: 4
Engine: 6
Transmission: 5
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
hrm, i have one of those sitting in my garage =)
monte87cortez
Sep 26, 2015 08:10 PM
