High performance Transmission help
Old Mar 17, 2005 | 05:49 PM
12secformula's Avatar
Car: 94 Z-28
Well I am trying to get an Auto tranny for the new project. I am torn between a TH350 or TH400. I am going to be buying a transmission completely done....it has to hold up behind 520-550hp NA...and a small shot of spray. Any suggestions on a which model would be best and a good brand would be greatly appreciated. I will be running a ATI 8" MRT converter if it matters. Also I have yet to decide whether or not to get a transbrake or not too. Let me hear what you guys think!!
Kyle
Old Mar 19, 2005 | 05:19 AM
Night rider327's Avatar
Car: 1988 Camaro
If you don't want to worry about it no more, just change filter and fuild 1 or 2 times a year, buy a th-400 and forget about it.
It's alittle heavier than a th-350, has alittle higher gearing (2.52 vs.2.48), but it's one if not the stronggest trans designs around.
I like to get my transmissions done buy a local shop. That away if there's any probs it can be took care of fast and easy. There's a good performance trans shop about 20-25 miles south of me, that I got to rebuild my th-400. I took a core in and he built it for $500. If you want to go that route, go to your local drag strip, dirt track, etc and talk to the guys there and see who does thier trannys.
If you want to buy outright check with chris at www.ckperformance.com He's out of NY, but does one hell of a job on performance trannys, and a pretty good price on his stuff.
A brake will be faster no question, but is your car set up for it? Is it a full time, nothing but drag car? Are you racing for track champ, points, money or just playing and running test and tune?
You will need a strong rear end, driveshaft, u joints, converter, etc for a trans break. So unless you have a ford 9", chevy 12 bolt, etc dont even think about it unless you dont mind ripping a rear end up every weekend or so.
Will you have the traction for a brake? If you cant dead hook the car (1.30's-1.50's) 60' time, theres no reason for a brake as it will just cause more wheel spin
Old Mar 19, 2005 | 07:22 AM
Car: 94 Z-28
Thanks for your help, I am pretty set on a TH400 anyways, I had just heard from a bunch of people that I don't need something like that. I will probably buy a complete tranny just fore ease right now. I always maintain everything so that will be no problem either. I will be running a Moser 9" rear and it should hook very well. The engine is a glorified street engine, we are setting the car up like a drag car but will also play the role of a sleeper...If ya saw the car you would know what I mean!! I probably won't run a transbrake because they are hard on equipment. My combo is a 385 stroker, 4000 stall, 4:11 gears, 28" tire....and a race weight of 3200-3300lbs w/ driver. Oh, I will be doing alot of bracket racing this car, but it will be doing a fair amount of street duty also.
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
