Tranny shift points
Old Mar 21, 2005 | 12:06 PM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
Tranny shift points
Two weeks ago I brought my 1985 Z28 305 TPI to a tranny shop because it wasn’t shifting into 4th gear. The guy said that it wasn’t shifting because the speedo cable was broken. He replaced the cable and the tranny shifted fine so I had him do a tranny flush and service, set the TV cable, install a .5 boost valve, a corvette servo, and a shift kit. When I picked up the car, the tranny shifted pretty good. After a couple of days, the shift from 3-4 went from shifting at 35-40 mph (2000-2500 rpm) to shifting at 55-60 mph (3500-4000 rpm). The guy at the shop said that there was nothing wrong with the tranny. What can I do to bring the shift back to the 35-40 mph range? The tranny is from a 1986 Caprice with a 305 motor.
Old Mar 21, 2005 | 02:37 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Inspect thr governor. Gear may be stripped or valve inside it may be hanging up.
Old Mar 21, 2005 | 02:39 PM
ace16a's Avatar
Engine: 5.0 TPI
How many weights should be on the gov.? Mine has none.
Old Mar 21, 2005 | 02:49 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
2 weights, 2 springs
Old Mar 24, 2005 | 10:16 AM
ace16a's Avatar
Engine: 5.0 TPI
Yesterday, I had to take a small trip. I drove 400 miles round trip. About half way through the trip, the transmission started acting funny. If I slowed down at all, the tranny would down shift to third and hold it for a while then shift back into OD. As I stated before, the tranny is from a 1986 caprice. Would it help out anything if I put the valve body from my original tranny into my now one?
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
