Speedo Gears Colored?
Old Apr 13, 2005 | 03:11 PM
  #51
Joehrdcor's Avatar
Car: 89 Firebird Formula
Engine: 305 TBI
Thanks for the link. I'm sure I'll figure it
Old Sep 30, 2005 | 01:46 PM
  #52
darrells3rdgen's Avatar
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
Originally posted by miacamaro305
im getiing 3.42 gears and i have right now 2.73,wat gear drive do i need to have to get an accurate speed reading?
my car also came with 2.73 gears with a 700r4 trans, and now Iinstalled a 3.42 rearend in the car. im running 295/50 r15 in the rear.
what vss gears do I need. I just called my local ''gm parts'' and they need to know how many teeth the gears need to be.
can you guy's help?
Old Sep 30, 2005 | 02:03 PM
  #53
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
3.42's with those 295 tires will take a 15/39 or 17/44 VSS gearing combo. Depending on which gears you currently have, I'd stay with the current drive gear. Most likely 17. Then the 44-tooth driven gear has part # 25513051.
Hope this helps.
Lou
Old Sep 30, 2005 | 02:19 PM
  #54
Car: 86 trans am
thanks. very helpfull.
is that a gm part number?
Old Sep 30, 2005 | 02:23 PM
  #55
BigBadLou's Avatar
Engine: TPI
GTAman
Aug 27, 2015 10:29 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
LT1Formula
Aug 20, 2015 09:36 PM
