how weak is weak?
Old Mar 28, 2005 | 10:54 AM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
how weak is weak?
ok i had a couple questions. first off i have an 88 iroc with a 2.77 posi rear. i was wondering. i have a 7.5 in ring gear. also i know the 10 bolts are not very strong factory. i had been looking at saving for like 2 years for a moser 12 bolt for 2,100 $$$ does anyone know about what a 10 bolt can handle horsepower an torque wise? i was thinking of a new eaton performance aftermarket carrier and a 3.73 ring and pinion combo. also how many splined axel do the 88's have 26? i dont know much about rear ends yet so keep the insults to a minimum. thanks
Old Mar 28, 2005 | 11:19 AM
ede's Avatar
ede
26 spline, how much HP it will hold depends a lot on how you set it up and how you apply the power
Old Mar 28, 2005 | 11:36 AM
l98+t5's Avatar
ok i know there are to many variables in my question for an exact answer. but this is a very hypothetical question. ive seen some guys running aftermarket carrier,ring ,pinion,and axels in a 10 bolt and have a 450 hp motor? this doesnt seem feasable. my original plan was to replace it with a moser. then find a drop out LS1/T-56 combo but if the 10 bolt can support this power with a few aftermarket beefy parts there is no need to replace it
Old Mar 28, 2005 | 02:32 PM
ede's Avatar
ede
ls1 used a 10 bolt from the factory
Old Mar 28, 2005 | 02:35 PM
l98+t5's Avatar
yes but didnt they have a different size ring gear like 8.5 or 7.625?
Old Mar 28, 2005 | 02:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no.. its the same gears.
LS1 cars had 28 spline... and some had a diffrent (stronger) posi...
but, you're wasting your money beefing up a 10bolt... because no matter how much you beef up one part, theres another part thats still too weak.
Old Mar 28, 2005 | 03:34 PM
rjmcgee's Avatar
A well setup 10 bolt can handle 1000 hp.
As long as you don't get any traction.
Falcon50
Aug 22, 2020 03:26 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
lanceflame44
Sep 25, 2015 12:28 PM
Racerx974
Sep 19, 2015 10:16 AM
cstrobel65
Sep 16, 2015 11:54 AM
