Need Help Speed O Fix please
Old Mar 31, 2005 | 01:46 PM
Art Heron's Avatar
Car: 87 IROC
Engine: 5.7
Transmission: Automatic
Need help with Speedo gears. I have an 87 IROC 5.7 automatic with a 9 bolt. Changed 3:27 gears to 3:73. I have stock tires. What parts do I need to adjust the speedometer?
Thank you,
Arty
Old Apr 1, 2005 | 11:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JMD on this board can fix you up with all that you need. Do a search on his name.
JamesC
Old Apr 1, 2005 | 12:33 PM
Art Heron's Avatar
Car: 87 IROC
Engine: 5.7
Thank you
I sent JMD a personal e-mail asking for his help. Thank you for yours.
Old Apr 6, 2005 | 02:02 PM
Art Heron's Avatar
Car: 87 IROC
Engine: 5.7
Anyone else that can help?
Thanks,
Arty
Old Apr 6, 2005 | 03:52 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Ok, I can only assume (for now) that you have a mechanical speedometer and stock 25.6" tall tires. If anything is different, please let us know, it will influence the gear selection for your speedometer.
If you have the purple 10-tooth drive gear, you will need the green 29-tooth driven gear (#25524924).
If you have the white 13-tooth drive gear, you will need the blue 38-tooth driven gear (#25522483).
If you have the red 17-tooth or yellow 19-tooth drive gear, you will need to change it to one of the above drive gears. There are not driven gears that would match these to give an accurate reading. The part #'s are 8628838 for the purple 10-tooth drive gear (I know who's got one for sale) and 8634934 for the white 13-tooth gear.
Hope this helps.
Lou
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
WIzmo
Aug 30, 2015 02:30 PM
InfinityShade
Aug 22, 2015 08:00 PM
