One more stupid question about posi
Old Apr 2, 2005 | 02:13 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
I found out a lot more then i did about posi's and what not, but here's the last stupid question...
This Eaton posi unit has EVERYTHING right? just need to slide it in?
http://www.thunderracing.com/catalog...vid=6&pcid=279
I'm looking at the 26 spline one, since mine has originally 26 splines. and that's a 3.23 gear right? no needing to buy the 3.23 gears?
Old Apr 2, 2005 | 04:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it is a direct bolt-in; but IF AND ONLY IF you have 3.23 or higher gears. It WILL NOT WORK UNDER ANY CIRCUMSTANCES with 3.08 or lower.Franky, however, if I was you and was laying out that much green for that plus the bearings you'll need plus the fluid plus the hassle, I'd sure get a 28-spline one instead, and new axles such as these.
Old Apr 3, 2005 | 12:58 AM
Car: '94 Z28
Engine: LT1 350
dang....maybe i'll keep my sad non-posi for now
Cleotiz
Jan 6, 2018 08:56 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
mcgarnicle
Aug 12, 2015 04:58 PM
