Rear End Ratios
Old Apr 9, 2005 | 05:17 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Rear End Ratios
What is the rear end ratio for these Camaros? I have a 1991 automatic RS 305 TBI. I haven't meet anyone that knows. Thanks.
Old Apr 9, 2005 | 05:47 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Being an auto and tbi, id say 2.73. 5 speed sticks got 3.08's
Old Apr 9, 2005 | 06:07 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Ok. I know it was less than a 3.00, but didn't know. So, a 5-speed car with a 3.24 posi-trac rear end would be a stiffer take-off, right?
Old Apr 9, 2005 | 06:29 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
It'd be easier for it to take off and a little stiffer because it's posi, but the top speed would be lower then a 2.92 or what ever if it was a 3.23
Basically
1) higher the gear, more take off power, lower top speed
2) Lower the gear, less take off power, higher top speed
And check the console for a number starting with "G", that's the gear ratio and here's the codes...
GU2 - 2.73
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
GW6 - 3.27
GM3 - 3.45
GT4 - 3.73
G80 - posi
G92 - performance
Old Apr 9, 2005 | 07:11 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
Its either going to be a 273 are a 308. Most likely a 273 with it an auto. Unless it was upgraded sometime along the line.
Old Apr 10, 2005 | 12:26 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Pull the differential cover and take a look.
Old Apr 10, 2005 | 06:58 AM
ede's Avatar
ede
whaqt it left the factory with, as confirmed by rpo codes and what it has are two differant things, pull the cover and look and you'll get a free oil change along the way.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
