is this rare?
Old Apr 14, 2005 | 09:57 PM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
is this rare?
i have an 88 iroc with a 350 tpi. an aluminum driveshaft. 4 wheel disks with aluminum calipers. and a 9 bolt posi rear end. is this a 1le? i have no door jam tag so its tough to say. does anyone know where i can get any more info on this rear end? all i know is its a full floating rear witha 7.75 inch ring gear and 28 splined axels. it would definitly be worth rebuilding correct? over buying a 12 bolt for 2,400 ? i highly doubt its a 1LE but i know the 9 bolt isnt common
Old Apr 15, 2005 | 06:50 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
No, it is not a 1LE car. 9-Bolts were common with 350TPI cars until 1989. The gear ratios were 2:77 and option of 3:27 and both required the Limited slip option G80. I highly dought you have the 11.655 dia rotors & and Aluminum calipers on the rear. These came out in 1989. If you have them then the rear may have been replaced. Picture of 89 PBR rear brakes.
The 9-Bolt is a stronger rear and worth keeping, so why do you want to rebuild it?? If nothing is wrong with it, just change the lube and run with it, if its not broke why mess with it.
Do a search and you will find more info on the 9-Bolt then you will never want to know.
Old Apr 16, 2005 | 07:16 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
this is a big mistake many people say. yes 1988 did infact have the pbr rear brakes (it was a mid year production) this goes along with the vats not being in 1988 cars which it was just as an option
to the question It could be a 1le but, not very likely . as far as I know only firebirds could be had as a 1le in 1988 and are very very rare only 2 known of.
your combo for an 1988 camaro is not a "common" one but, not even close to rare I would venture it was a late production 1988 camaro
Old Apr 18, 2005 | 09:24 AM
l98+t5's Avatar
i was led to believe that there were 4 iroc 1LE's made in this year. i know i know my chances are like one imn a million. but does anyone know the production numbers for this rear end in 88? also any aftermarket companys that supply beefy parts for it? ive already been to diff solutions. any help would be great
Old Apr 18, 2005 | 01:19 PM
HawaiianRS's Avatar
Car: 1989 RS
Engine: 5.0
If I'm not mistaken if you have A/C that would be a dead give away that it is not a 1LE, also you said disc all around but not wether the fronts were single or dual piston.
Old Apr 18, 2005 | 01:28 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
There is a 99.9% chance that it is not a 1LE but if you really want to know check your RPO codes for "1LE".
Old Apr 18, 2005 | 03:59 PM
DJP87Z28's Avatar
Forget about it being a 1LE and be happy with what you have.
Parts for a 9-bolt, you got to be kidding. For your info parts for that 9-bolt are the rarest thing on your car. Just run with it, the only way its going to break is if you abuse that rare rear.
Old Apr 20, 2005 | 09:53 AM
l98+t5's Avatar
yeah i dont really care if it is a 1le either. but the thing is that it has been abuse and i wanted to rebuild it with stronger parts. on www.9bolt.com they have a package that includes the posi unit 3.73 ring and pinion and the installation kit for 900 bucks. i would like to do this but i dont want to replace the posi unit with a stock cluth pack style posi. kinda comfused as to what type of posi this rear had?
Old Apr 20, 2005 | 12:38 PM
DJP87Z28's Avatar
You should read up on the information on this site about the 9-bolt rear and then you will know why parts are hard to find & expensive. One other important note! 9-Bolt & 10-Bolt parts are NOT INTERCHANGEABLE.
Old Apr 21, 2005 | 01:28 PM
l98+t5's Avatar
yeah i know that the parts are not interchangeable. but the thing is i can build a strong 9 bolt for about 1,000 -1,200 or i could built a weak *** 10 bolt or buy a 12 bolt for 2,400 ..............which would you choose .............9 bolt id say. my only big concern is what diff i can get for this rear end. i dont want a clutch pack style. i would like a torsion. but i dont know what is out there i cant find many aftermarket carriers for this rear any ideas?
Old Apr 21, 2005 | 01:42 PM
DJP87Z28's Avatar
You are stuck with what is stock for the 9-bolt. NO ONE makes a aftermarket limited slip for that rear.
Old Apr 21, 2005 | 05:56 PM
l98+t5's Avatar
not that i dont trust your judgement but is there anyone that can back him up on that. what about the package on www.9bolt.com with 3.73 gears installation kit and carrier? is this just a stock replacement
Old Apr 21, 2005 | 07:17 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Nine-bolt pros: Stronger then the ten-bolt. One less bolt to remove when taking to cover off.
Cons: Almost a total lack of aftermarket. Hard to get parts for, unless you find one in a junkyard - but then you risk getting just that, junk. Ten-bolts can be built up, that or you could just drop a Ford 9" in there, but you need to run some serious power to need a 9"...
I'm going to keep both of mine, but if they go, well, I'll burn that bridge when I get there. I think the 3.73 gears from that site are stock gears off another application, but don't quote me on that.
Old Apr 26, 2005 | 08:43 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
http://www.1le.net/1le_production.html
Old Apr 28, 2005 | 06:30 AM
TRANSAM38387's Avatar
Car: 1987 GTA
i have a 87 gta with a 9 bolt and it says borgwarner on the bottom, what year did they start putting these rears in our cars
Old Apr 28, 2005 | 01:32 PM
l98+t5's Avatar
88 i believe.
Old Apr 28, 2005 | 02:43 PM
DJP87Z28's Avatar
BW 9-bolts were used in various gear ratios on Camaro/Firebirds from 1982 until 1989. They were discontinues in model year 1989 as being to expensive for GMs beancounters.
Linson
Oct 24, 2025 02:00 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
sjorgens
Oct 1, 2015 07:54 PM
