Reuse or Replace? 1st time axle rebuild
Old Apr 14, 2005 | 11:47 PM
Project Z's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 Bolt, 3.23 Posi
I’m in the process of rebuilding this 9 bolt that I’ve been sitting on for a while. This is my first attempt at this so I’m taking is slowly and I need some advise.
First – the car is for the street only, no track days or drag slicks. I’ll be abusive enough on the street.
First things off were the axle shafts. Do these look like they’ve got life left in them? And the shaft bearings…are these an automatic replacement item, or can they be repacked and reinstalled?
Lastly, can someone clue me in on how to put multiple attachments on the same message? I know it’s annoying to people when I have to make a new message for each picture
Attached Thumbnails Reuse or Replace?  1st time axle rebuild-shaft-splines.jpg
Old Apr 14, 2005 | 11:48 PM
Project Z's Avatar
Car: 1987 Iroc Z28
Axle shaft bearings. From the same axle.
Attached Thumbnails Reuse or Replace?  1st time axle rebuild-shaft-bearing.jpg
Old Apr 15, 2005 | 01:03 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
That Axel looks fine to me, not very much wear indicated by the Pic.
I always change the Axel bearings if the rear has High miles on it, just to be safe. But, if the bearings aren't pitted or burnt (bluesh color) than you would be OK to reuse them.
Old Apr 15, 2005 | 10:37 AM
Project Z's Avatar
Car: 1987 Iroc Z28
follow-up question
Thanks. I guess I'll take a long, close look at those bearings before deciding to reuse them.
Another Question: When everything is out of this sucker, is it worth the time to weld the seams where the tubes enter the center section?
Old Apr 15, 2005 | 05:37 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
I would, just for peace of mind. I normally pay around $45 to have it done by a Rear End shop. Since they have Jigs to make sure the axel houseings don't pull.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
red90IROCls1
Aug 25, 2015 06:56 AM
hokis
Aug 9, 2015 03:57 PM
