SGI-5B wiring
Old Apr 19, 2005 | 01:01 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
SGI-5B wiring
I just bought the sgi5b box to recalibrate my speedo after rear gear swap and came up with a little diagram to help folks out. I contacted Dakota Digital and this is how they told me to hook it up. My car is a 92 Camaro w/TPI 5 speed. Enjoy!
Old Apr 19, 2005 | 07:39 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
hey mods...I'd make this one a sticky....I think I'll need it in like 6 months when I get back
Old Apr 23, 2005 | 09:36 AM
pwdbychevy's Avatar
I wired it up as the diagram says and I get a signal but haven't fine tuned it yet. I am running into the problem of the speedo showing a reading while at a dead stop. I'm thinking it could be noise interference causing this. After research, I found this diagram from a Chevy Impala website on how he hooked it up to minimize the interference. As you can see, he cut the purple wire and hooked it into ground and left the ECM side of the purple wire taped up and also is using OUT3 instead of OUT1 like the first diagram shows. I'm going to try this method today. I bought an inline noise filter at RadioShack for 10 bucks. I'll get back with yall on the results.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
