non-lockup TC in lockup tranny
Old Jul 25, 2003 | 01:29 PM
BADBIRD009's Avatar
Does anyone know what needs to be done to a 700r4 to put a non lockup TC in?
Old Jul 25, 2003 | 01:38 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Nothing!! I had one in my 91 for 2 year's with no problem's. Then I bought a TCI with lock-up. If you really are picky I suppose you could program the chip to not lock-up the converter or something If that is even possible, it is'nt a must though.
Old Jul 25, 2003 | 11:21 PM
Rage13's Avatar
Car: 89 Firebird
uh.. why would you want to put in a TC without lock up?
Old Jul 25, 2003 | 11:45 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I'm not sure why you would want to do that either but if you do, you better get a really good tranny cooler because is it going to run a lot hotter. If you are doing this to a stock transmission, good luck and start saving your money for a new tranny.
Old Jul 26, 2003 | 09:08 AM
BADBIRD009's Avatar
It can be done. At least according to torco, which is who I got the converter from. And the reason I am doin it is because I am goin to a carb and will not have an ecm. Because my firebird is just a weekend car I do not care about gas mileage, which is about all you're gettin with that lockup.
Old Jul 26, 2003 | 06:24 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
id like to know why or how a tranny would run any hotter minus the lockup feature,
Old Jul 26, 2003 | 06:34 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
The way it was explained to me is that "because when it is unlocked it is slipping which builds up more heat".
Old Jul 26, 2003 | 08:01 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
converters always slip, what can you do about it ? th350, 400, etc, they all slip all the time, never lock up, cept the few C models they produced. th350 is one of the most reliable they made, and 400 too. they survive well over 100k miles in the big 1 tons and sometimes larger,
also, i have been running my 83 caprice 700r4 in the same 83 caprice for months now with lockup unplugged, works fine, no problems at all, clean fluid bright red still and everything. and thats an early 700r4 with 90,000 behind original 305 LG4, i got tired of it locking up at 30mph in and out all the tiem so i yanked the plug on it
so hmmm.,.
Old Jul 27, 2003 | 12:12 AM
Rage13's Avatar
Car: 89 Firebird
well, you know the lockup is a good thing right? it stops the converter from sliping, giving better gas mileage and less power loss thru the drive train. its basicly an electric cluch that locks the fly wheel to the trans.
Old Jul 27, 2003 | 07:34 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
This might be of interest to you:
http://store.summitracing.com/search...rt=prf%2D60109
Benefits as mentioned, lower operating temp and better gas mileage, longer tranny life.
Old Jul 27, 2003 | 07:36 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Sorry, double post.
Old Jul 27, 2003 | 11:01 AM
BADBIRD009's Avatar
Well, there are certanly a lot of interesting anwsers but nothing that really answers my question. Except for 91wtROH17's which is do nothing. Anyone else agree?
Oh yeah Fevre that module is to KEEP the lock up without an ecm, but thanks anyway.
Old Jul 27, 2003 | 11:23 AM
Rage13's Avatar
Car: 89 Firebird
well to answer your question, like 91wtROH17's said "nothing"
just put the TQ in and thats it..
Old Jul 27, 2003 | 06:14 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
all torque converters slip, excpet lockup feature ones in final gear at certain minimum vehiucle speed, just cuz is not connected not locked in doesnt have to mean that its bad for it, they slip anyways at all other times,
i stand by that unless my 1983 original 700r4 pukes on me out of the blue, in which i highly doubt.
good luck with oyur 700r4, BADBIRD
Old Jul 28, 2003 | 11:22 PM
cael's Avatar
If I remember correctly, the man who rebuilt my tranny had to change a valve in the pump or somewhere near it to route the fluid correctly to compensate for the fact that a non-lockup was being put in. He also told me to leave the front o-ring off that goes on the shaft the TC sits on. He sounded like he knew what he was talking about (and the 8.4 sec 69 firebird in his garage makes it look like he does). The reason for the new valve and the 'forgotten' o-ring was to push 100% of the tranny fluid through the cooler, as opposed to 30% flow which he said would result.
*shrug* I just know my car moves faster than it did
BTW, Mickey at Torco told me he changed his TC style, he sells billet (sp) style TCs more inline with what Vigilante makes. Costs 300 now instead of 190 tho
Old Jul 29, 2003 | 08:03 AM
BADBIRD009's Avatar
Thanks everyone for your help. Turns out i gotta do what cael says. The cool part is Torco sent me the kit I need and instructions with my converter for FREE! These guys are great to deal with, hopefuly Im as happy with the converter as I am with their service.
Thanks again
Old Jul 29, 2003 | 11:34 AM
Car: 91Z
I guess that's the proper way, but I did none of that and had no problem's at all!!
Old Apr 22, 2005 | 06:35 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok forgot about this one
im not done with it lol
not to be a pain or anything but i want to learn also and this is the only way to currently
the o ring on end of the shaft of the lockup trannies is small diamter and non splined
the non lockup input shafts are big diameter and two sets of splines and i cant see what would make any difference at all by rmeoving or not rmeoving the o ring its not gonna touch anything inside of a non lockup converter at all the lockup shaft end is so tiny compared to a non lockup one, big time
lockup shaft looks longer than non lockup one also but a bunch, all thanks to the extra small diameter non splined length on the lockup shaft
i did put a non lockup converter on the 81 lockup th350c i ahve and it seems ot go on but didnt make as good of clicks going on as it should however
im just not sure,,
i think this needs to be discussed a bit more so no one ruins anything on their ride..
right ?
no ?
cuz this 81 th350c trans i have is a real good heavy DX diesel dual bolt pattern long length one i really want to keep it but i cant be retaining the diesel converter and i dont care about losing lockup ill never find a gas lockup verter anyways, so,,
im jut not convinced at all that any damage can occur to a trans due to fluid flow or slippage or whatever by not running a C verter in a non C trans..
less someone has positive info/proof somehow ?
thanks
Old Apr 22, 2005 | 07:02 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Just to clear some things up, the 700R4 is an overdrive transmission, unlike the THD350 or THD400, and in fourth gear the engine RPMs at cruise can be close to (or below) the stall speed of the converter. Near and below stall speed, the converter will slip much more than at higher RPMs. This extra slippage produces the higher tranny temperatures that you won't find in a THD350/400 that cruises at a higher RPM (1:1 final drive). This is why the lock up is required to reduce tranny temps in the 700R4. If you've installed a higher stall converter your tranny could generate even more heat if it's cruising significantly below the stall speed.
If you go without lockup you can: install a tranny cooler, higher rearend gears, cruise in third, rebuild your tranny soon.
Old Apr 23, 2005 | 02:33 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
so th350 c with a non C verter in it is fine then
i could see on a 700r4 though it being bad without lockup i guess although i have run some with without lockup connected and had no issues
also on the early 90's 4T60 trannies(FWD) i have unpludded many lockups on these and never had any issues, we have a 90 cutlass calais with 4T60 in it and its been run a few thousand miles with it unplugged cuz it was sticking and killing the engine at stops in gear, and it runs fine no problem at all, its mostly all highway driven
thanks
Old Apr 23, 2005 | 09:57 AM
naf's Avatar
naf
You may never have a problem, depends on alot of different variables, but without lockup you are shortening the life of your transmission.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
