Replaced the bad 3.27s with a winey set of 3.70s..help
Old Apr 19, 2005 | 11:52 PM
d21jim's Avatar
Okay....my father and I are restoring an 89 formula 350 that came with 3.27s. The unit went bad so we decided to buy a new unit from diff solutions. We put the 3.70s in and noticed a loud whine.....okay back to the garage....we bring in a gm mechanic(father's friend)...check the tolerances ...backlash...ect...put it back together drive it down the road....now a slight whine has decided to rear its ugly face....any suggestions............all help is appreciated....thanks guys...
Old Apr 20, 2005 | 02:02 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
Most all Aftermarket gears will whine. Some louder than others (Richmond) is the loudest I've ever owned. Even factory will whine, but not as load as aftermarket.
Old Apr 20, 2005 | 09:48 AM
d21jim's Avatar
thanks......this is the borg warner 9 bolt.... ...so do you think we should leave for the time being?
Old Apr 20, 2005 | 09:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
well as long as the teeth are contacting the pinion teeth right, then it should be fine. like said, all gears whine a bit.
Old Apr 20, 2005 | 10:43 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Once a wear pattern is established, you will never get rid of gear whine no matter how much you adjust it.
A tiny bit of whine is ok. Loud is not tho. The whine is also a vibration and will destroy the gears in the long term.
Old Apr 20, 2005 | 10:46 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Most 3.70's (after market) tell you right on the box they are noisey. Us Gear, Yukon, Precision Gear and others.
I think they all buy from the same place and rebox them (9 bolts)
Old Apr 20, 2005 | 10:49 AM
12secformula's Avatar
Car: 94 Z-28
I had 3.70's in my car, they were professionally installed in the 9 bolt and they whined alot. Don't worry about it man. They all do it.
Old Apr 20, 2005 | 02:13 PM
d21jim's Avatar
Thanks guys.....my old man was all fired up about it....we've got some good money in this formula 350(white G92 ws6 with t-tops) eventually we'll get some pics going.....
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
86IROC112
Apr 9, 2016 10:20 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
