3:73 or 4:10?
Old Apr 20, 2005 | 02:58 PM
RacerDonnie13's Avatar
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
3:73 or 4:10?
i need an opinion on which gear ratio to run 3:73 or 4:10. Motor is a 383 SBC roundabout 400 hp and im running a Th-350 trans. It will not be an everyday driven vehicle. Probably like once a week or so. and an occasional trip down the quarter mile. being that the trans is only a 3 speed im not sure if the 4:10 will be too low to drive on the street but then i want the car to take off good so i dont know if the 3:73 will be too high. Also what is a good posi unit to run? Thanks
Old Apr 20, 2005 | 03:26 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I've run a th-350 for about 10 years now, but am now in the process of changing over to 700R4 since changing the rear gears to 3.73's. With those gears on the highway I was turning to many rpm's for my liking. I don't know that I would go to 4.10's unless I was running overdrive. A friend of mine who does run 4.10's says it too much for the street without overdrive. He says he wants to drop back to 3.73 or even 3.42's. I had the 3.42's but really like the 3'73's. Good luck in your choice.
Old Apr 20, 2005 | 03:32 PM
Car: 1988 Camaro SC
Engine: 383 Stroker
How many RPM's were you turning on the highway with the 3;73's
Old Apr 20, 2005 | 06:44 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
At 60 mph I would be running around 3000-3200 rpm give or take. When I started going to further shows and was running 65-70 mph on the freeway I would be close to 3800-4000. Probably didn't help that I have a short tir combo either which adds to the rpm's.
Old Apr 20, 2005 | 07:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
This is my only regret about going from a T5 to a T10 4-speed. Meh.. I'll get over it
Old Apr 20, 2005 | 11:10 PM
Pro Built Automatics's Avatar
Being a 383ci. on the street, I would stick with 3.73's and a Continental 10" with the TH350 transmission. A good 7.5" posi is the Eaton. Call me if you need one?
PurelyPMD
May 5, 2016 04:57 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
Mark A Shields
Aftermarket Product Review
Aug 13, 2001 09:44 PM
Bob 91TA
Mar 19, 2001 11:07 PM
theformula
Oct 18, 2000 12:46 AM
