9 Bolt
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
9 Bolt
Did Pontiac's ever come with factory installed 3.70 gears in the Borg Warner 9 bolt I just got one and the tag on the cover says it has 3.70 gears I thought 3.45 was the highest gear you could get with a 5 speed but i might be wrong
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Re: 9 Bolt
- Common factory ratios were 2.77, 3.27 & 3.45, uncommon factory ratios are 3.08. After market ratios are 3.70. Ratios that I offer are 3.23, 3.45, 3.73, 3.9 & 4.10 (actually 5.13 but bring your visa card, and 3.9 is special order).
Engine: 364 Ci Ls2
That's strange cuz the guy i got the rear from said it came out of a stock 86 WS6 5 speed with a L69 305 HO car i know in 86 you could get 3.73's in the 10 bolt but it dosent say anything about the 9 bolt
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
3.70 gears were never offered in a production car. They were available from GM over the counter back when the cars were new. Maybe when you bought the GM gears, the tag was included.
Engine: SBC, LS-x
I wonder what kind of a nightmare it would be to get spedo gears for that ring and pinion. Might have to use the ones for 3:73's.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
they did come on very few l69 manual cars. I have seen listings for it in 85-86 and I know there is a post in here with the picture of the tag (just like the one I am sure you have)
the 10 bolt was also affered in a 3.73 in the early years as well
Engine: ls1, LB9
https://www.thirdgen.org/techbb2/sho...+bolt+3.70+tag
here you go and it also says the rpo code is gs4
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
