Small crack on tranny, what can I use to patch it ?
Old Apr 24, 2005 | 11:43 PM
zap89's Avatar
Car: 1989 Formula
Transmission: Finally a working 700R4
Something must have come up up and hit my tranny. Now I have a very small leak on the case, so small you can't see the crack but, after a minute fluid will start to seep through and I mean just seep. Anybody use something that will stop this ? Yeah replacement is best but want to stop leak now.
Thnx,
Old Apr 25, 2005 | 12:25 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
jb weld ... epoxy ... quick steel ... none of them will work as long as there is contamination (trans fluid) but you might try rubbing it with a bar of soap then wipe it clean and use one of the above ... ive never used soap on a tranny but i have used it on a fuel tank leak to get through a couple more races ... either way its just tempoary ... good luck ... tao
Old Apr 25, 2005 | 12:48 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i'd suggest draining it, then spraying it with brake-kleen or something like that and wiping it until it's über clean, then use a 2 part epoxy and "paint" it on. Should hold...
Old Apr 25, 2005 | 09:10 AM
zap89's Avatar
Car: 1989 Formula
Damn..thanks alot for the help great ideas
Jorlain
Oct 8, 2015 01:57 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
