early 3550 swap question
Old Apr 26, 2005 | 01:49 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
i have an early 3550 converted for a gm application with a gm 26 spline input shaft that was for a 70 chevelle...my T5 is on its way out so i wanted to swap the tranny in place of my T5...my question is what bellhousing can i use..i know lakewood makes a bellhousing for the 3550 but it is for a mechanical clutch setup which i don't have...im curious if the 84-92 bellhousing has the straight bolt pattern so it would bolt right up or am i going to have to convert to a mechanical clutch? if so where would i find the mechanical clutch linkage? i called fortes a few times as that is where the transmission was purchased but have alot of trouble with getting called back or email response...
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
