T-10 hurst shifter, loosening periodically
Old Apr 26, 2005 | 03:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I have the T-10 with some sort of hurst shifter in it. There are 2 3/8" fine thread bolts holding the shifter shaft onto the... other part...?
Anyway, those two bolts work themselves loose quite often, probably around 2000kms and I need to retighten them... I had put some standard lock washers on them, but they still re-loosened....
Is this common? Is there a better method to keep them in there? Safety wire? blue thread sealer? I don't want it to be a total pain to remove, if I ever have to remove it, that's why I didn't just throw some red thread sealer in and be done with it...
Thanks -J
Old Apr 26, 2005 | 04:21 PM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
this happened with my t-5 hurst shifter. the bottom bolt completely fell out on me on the highway, as you can imagine, it wasn't much fun. i just used lock-tite on the bolts and they haven't moved since.
mattcanty
Oct 12, 2015 11:08 AM
ndndndnd
Sep 28, 2015 08:00 AM
