posi slipping?
Old Apr 26, 2005 | 06:49 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
posi slipping?
How do i tell if my posi is slipping? When i shift from first to second, or give it like 2/3'ds throttle right off the line it feels like the rear right tire is doing something funny, not sure exactly what though. However I can do a brake stand and both tires leave marks, and when its floored and does the 1-2 shift both rear tires break loose so i dunno. I guess i'm asking is what i'm describing normal? This is my first posi, just got her out a couple weeks ago. Its a BW 9 bolt if that makes a difference.
-chillen
Old May 10, 2005 | 03:42 AM
johnnyb92rs's Avatar
same problem
my back right tire start doing this a few days ago I am at a stop and step on the gas I hear and feel this clunk. I thought it was the shocks and I put new ones in but that wasnt it.if you figure it out please let me know
Old May 11, 2005 | 10:09 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
check out the posi.
if it is a 9bolt like you said then do a search for the repair info. look for user name "88 350 tpi formula" and posi there are some real good pictures and it should give you a good idea how it works
bassically you could have worn cones and have very excessive back lash in the pinion gears
here, https://www.thirdgen.org/techbb2/sho...highlight=posi
jrdturbo
Mar 31, 2016 02:58 PM
KO1
16
Oct 15, 2015 05:00 PM
