How to know if my rear end is original??
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
What would i need to look for to know weather or not iv got the stock rearend in my 86 IROC car? Can i find out what gears came in the rear end with my VIN number? and then will i find a way to tell what the rear end ratio is by looking at it?
the whole reason is becasue the speedo is about 10 MPH too fast when im going about 55. i think the wheels are the stock size too.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The only way to tell what rear you have is to get the casting number off of it and take off the rear cover to look at whats inside. RPO codes only tell you what the car came with from the factory and not whats in it right now. If you run the numbers and count the teeth you will be able to cross reference that info with whatever your RPO codes say. If they don't match then you have another rear gear of some sort.
Engine: 305ci TPI
yea see i was hoping that actually counting wasnt the only way, but i guess so. i also thought that i could get a close idea with the calculator equation thing on this site but i would need to know my real speed, which i dont becasue the speedo is messed up haha
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could get an idea by jacking it up and counting how many times the driveshaft turns for ever time the rear turns, but it's probably time to change the diff lube anyway.
Car: '90 RS
Engine: 377 LSX
Originally posted by Nitsuj86Iroc
hmm, is there any interval that is set for changing the diff lube? certain miles or such?
Engine: 305ci TPI
ill take that advice and do it sometime soon.
and whats the easiest way to count teeth? i was imagining puting a piece of tape or something on a tooth to mark it, as long as it will stick good enough
Engine: 305ci TPI
oh ok, but im new to the gear thing, can the ring gear be original and the other be different? i dont think so i think they have to go together right? just wanna make sure, i like learning as much as i can about stuff like that.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
