9 bolt questions
Old May 2, 2005 | 02:01 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
9 bolt questions
I have a 2.77 rearend that I pulled out of my car when I bought it. I replaced it with a low miles 3.27 rear. My question is I have always heard this loud bang when I move the car from forward to reverse gears and out of N or P. It did this with the old trans/rear, but now with the new trans/rear it seems a little more pronounced, and it's not getting any better. What gives? I just went out and checked the old rear end and it seems nice and tight. Pulled the cover and spun the yoke and there is no play at all. Would play be causing this clunking? If so where can I get parts to swap a 3 series carrier and some 3.45's into my old 2.77 setup? The teeth look as if there is barely any wear also. This leads me to believe that the original rear must have been services at some point. I doubt it would look that good and the fluid that clean if it were all original 135k miles on it. Anyway can you guys point me in the right direction to get some parts to put the better gears in my 3.45? Thanks
Will
Old May 2, 2005 | 02:39 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
tranny mount?
Old May 2, 2005 | 02:42 PM
norcalz28's Avatar
the mount is fine
Old May 2, 2005 | 05:14 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
torque arm mount
Old May 2, 2005 | 09:52 PM
norcalz28's Avatar
OK, every mount on the car is poly with less than 10k miles on it
Will
Old May 3, 2005 | 02:45 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Have your friend in your picture sit in the car and move the shifter from N to P while you walk around the outside of the car. Check your u joints and the splines of the yoke as well as the splines of the output shaft of the trans. Also check the flex plate on the back of the motor for cracks.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
