TKO swappers, which shifter stick??
Old Apr 28, 2005 | 11:51 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Hey guys I am swapping out my 700R4 for a TKO600. I will be running the stock Tremec shifter but I dont have a shifter stick and am told a straight one will hit the ash tray. I was looking at Hurst shifter sticks. Which shifter stick do you guys run? how tall is it and how far bent back is it? part numbers? Thanks for the help.
Old Apr 28, 2005 | 12:39 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
No part numbers, but mine is fabricated, I dont have exact measurments. Its angled about 1/2 in towards the driver side with a bent plate with two holes on it that connect the handle to the base. Then on that plate there is a roundbar welded, moving the shifter back 1 1/2 inches or so, then up. The top is threaded for the shifter ball.
Old Apr 28, 2005 | 05:15 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
how tall is it?
Old Apr 29, 2005 | 02:51 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Anybody? I am gonna be ordering my parts in a few days and I am trying to order the right shift lever the first time LOL.
Old May 2, 2005 | 11:48 PM
TKOcamaro's Avatar
Car: 1988 Camaro
Engine: 40 over 350
I pulled mine in a junkyard from a late model mustang ( 96 i think ) I did need to make a new trim piece but then again i also have a custom setup. I am not using a spacer between the trans and the bellhousing ( Lakewood ) so you may have the clearance to use the stock piece. Also, the positioning and orentation of the lever is close to perfect. I also replaced the rubber bushing with brass bushings from ACE hardware. Here is a pic of the shift lever in my car.
http://www.half-fastracing.com/scamaro.html#
Just scroll down to the pics
As you probablly noticed, the info is a bit outdated!
Old May 3, 2005 | 12:04 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Thanks for the reply. I am going to try this shifter and run my stock console plate. hopefully it works out, you guys think this will work?
part number is HUU-5388550
http://store.summitracing.com/defaul....asp&x=20&y=11
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
