Hi! quick question on V8 t5
Old May 5, 2005 | 01:17 PM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Transmission: 5 speed
POST 001!
Hi all!
I have a 91 camaro 305tbi with a 5 speed. It is pretty much toast. Was my second car so I was letting a friend drive it.Anyways I believe its beyond a rebuild cause it sound like a blend trying to blend nuts and bolts. 4th gear was what i used to get it home. So I am looking to swap it out. Here lies the question. I am looking to keep my speedo and such. Thanks for your time.
1. What years can I look for?
Old May 5, 2005 | 05:27 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
83-92.
Swap over the VSS sending unit and your speedo drive/driven gears if necessary - they're color-coded.
Old May 5, 2005 | 05:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
More specifically, it must be a 83-92 Camaro/Firebird V8 T-5. No other will swap in directly. Not a 6-cyl one, not one out of another vehicle such as a S truck or Mustang, not a 93-up one. 83-92 V8 Camaro/Firebird. 88-92 would be preferred, as that's the dividing year between the 1st design, and the newer 2nd design like you have.
Old May 5, 2005 | 10:19 PM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Thanks for the info. Just wanted to make sure I could use any 26 pline for from those years.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
