Here's a different speedo gear question
Old May 5, 2005 | 10:11 PM
Abubaca's Avatar
OK, follow this thinking and see if I'm on to something here. Maybe this is so obvious that it didn't deserve mentioning, but I can't find ANY info on this.
I used to have a 17t drive gear and a 37t driven gear. I now have that same 17t drive gear, and a 44t driven gear, which gives me the appropriate ratio for the new rear.
Here's the concern. Obviously the 44t gear has a bigger diameter than the old 37t gear. How would it fit?
I have the new housing for 40+ tooth driven gears, but that doesn't move the axis of the driven gear at all. If the two gears that I used to have meshed properly, and you don't change either axis, but one gear size is changed, wouldn't that be problematic???
Old May 5, 2005 | 10:22 PM
Abubaca's Avatar
....I just found these combinations which all work for a 3.27 rear axle with 245/50/16 tires:
16 / 41
15 / 39
17 / 44
...They all are pretty darn close as far as ratio, but they are all physically different sizes.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
