Trans Am have posi or open diff?
Car: 1987 Iroc Z28
Axle/Gears: 9 Bolt, 3.23 Posi
Well, depends on the test drive
you could always light up the tires and tell that way.
Take a look at the rear diff cover, if it's a posi there might be a tag indicating as such. Or you could jack up the rear end and spin one wheel, if the other spins the same way, it's the real deal.
you could always light up the tires and tell that way.Take a look at the rear diff cover, if it's a posi there might be a tag indicating as such. Or you could jack up the rear end and spin one wheel, if the other spins the same way, it's the real deal.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Not all TA or all Irocs or all Z28's came with posi's. The only scientific way to tell is by removing the cover. Only cars that had rpo G80 came factory with a posi.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if both tires have equal grip and enough of a shock they both might spin
my rx7 did with an open rear so did my celica spinning both tires on the rear with open rear ends
with the jack the car up even that can't always tell. you might have a worn posi or something else going
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
