Should I get a new rear end?
Old May 15, 2005 | 09:50 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Its the stock gears for an 86 T/A and I'm wondering if changing the ratio will save me some time and make it more fun to ride. My only complaint is I cruise at 80mph and aabout 2300 rpms. I'd like to keep that lower if possible too, but I can't have everything I suppose. Any ideas?
Old May 15, 2005 | 11:06 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
go with some 3.73s it will up the fun level.
Old May 15, 2005 | 11:12 AM
klumb15's Avatar
3.73's will make it feel like a whole new car...you'll still maintain a reasonable amount of gas mileage, and it'll feel alot quicker....4.10's are real fun, but really really bad gas mielage...
Old May 15, 2005 | 04:29 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Do you have a stock tranny? 700-r4? if you have the auto id probably reccomend 3.42's i have 3.73's and feel that they are borderline overkill.
Old May 15, 2005 | 05:32 PM
klumb15's Avatar
is it a peg leg one wheel wonder rearend or do you have limited slip? because if you put 3.73's and keep the open differential your probably going to have severe traction problems off the line...
Old May 15, 2005 | 05:38 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
Do you have an automatic with overdrive? If so don't worry about gears too much...I know that my swap was not drastic but when I went from 2.73s to 3.23s I saw no decrease, in fact I saw an increase if anything (just a small one though)
The overdrive still keeps me in a very low RPM when I'm cruising the highway.
Old May 16, 2005 | 12:39 AM
Car: 86 T/A
Engine: HSR 355
Yeah, its a stock automatic tranny. I'm not really looking for it to feel faster, I want it to actually run faster 1/4s.
So stock is 2.73 from what I've read. Would 3.42 be the best option? Where should I look to get one?
Old May 16, 2005 | 07:45 AM
klumb15's Avatar
i would say 3.73's would be your best option...IMO its the best overall gear out....but look around, pretty much all performance sites have gears for sale...you need the one made for a 2 series carrier tho..
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
