What does TC lockup feel like?
Old May 16, 2005 | 12:59 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Just curious, how can I tell when my tc is locking, unlocking? ETC? THanks guys
Will
Old May 16, 2005 | 01:07 PM
kevinc's Avatar
Car: 1982 Z28
Tach will usually drop ~500rpm or so when the TCC locks, depending on your engine load at the time.
Old May 16, 2005 | 02:45 PM
norcalz28's Avatar
I ask because since going with my pro-built and vig 2400 alot changed. 1-2 is very short, then what appears to be 2-3 is also fairly short. It will hold until say 30 mph and then drop once more, significantly. Almost like another gear. And I still have OD left. The car shudders a little during this last rpm drop before OD.
Will
Old May 16, 2005 | 02:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That sounds like the TCC locking. If you have a "slippery" converter with a higher stall than stock, the RPM drop will be much greater and more noticeable.
Old May 16, 2005 | 03:01 PM
norcalz28's Avatar
Right on. I am just really paranoid about all these little things and figured I would make sure.
Will
Old May 16, 2005 | 04:25 PM
kevinc's Avatar
Car: 1982 Z28
I was able to smooth mine out w/ the Vigilante by increasing the lock/unlock speeds in software.
Easy to do following the DIY-PROM forum stuff.
Old May 16, 2005 | 06:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, when you're at highway speed (50 mph or higher) and just cruising (low rpm), keep your right foot steady on the gas, and with your left foot, press your brake pedal slightly down- about an inch- just enough to turn on the rear brake lights.
That'll disengage the TCC, RPMs should go up a bit. Let up on the brake pedal, and you'll go back into lockup.
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
