I Finally Cracked the Code on the Dakota Digital SGI-5B
Old May 18, 2005 | 10:22 AM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Well after almost a year of having a speedometer that read 20 when I was going 60ish I decided to get this thing calibrated. It started with pulling my head out of my ***, and actually thinking about what I was doing. Low and behold, it worked. They give you the chart of ratios in the instructions, as well as the ratio (that page was missing in my instructions, so I downloaded a new book) to figure out which one you need to get your speed close. After you get the speedo close, you adjust it with the up/down buttons to nail it. A little tip for tose of you looking for a place to start:
FYI, I have a 94 T-56 and a 3.27 rear.
Follow the directions for Application #3 except:
Set switch #4 to ON
Set the coarse calibration to 6
Set the fine calibration to 3.
That #4 switch was the sticking point, even the guy at Dakota Digital said it should definetly be OFF. After reading their chart (if you have their formula it makes a lot of sense) I figured that I'd try turning it on since that was the only way I could get the ratio high enough, and viola, it worked like a champ. The best thing is, once you figure out how to tweak this thing gear changes, tire changes are no longer a worry since you have infinate adjustability.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
stickychinsac
Aug 31, 2015 06:06 AM
