Need info on swapping from a manual to a auto
Old May 19, 2005 | 11:50 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Im wondering what all i need to get to swap a auto into my car. Im tired of messing with the manual and i want to get more into racing so im going for a auto.
Old May 20, 2005 | 06:15 AM
ede's Avatar
ede
depends alot on which trans you get. at the very least you'd need a shifter, cable, trans, and TC
Old May 20, 2005 | 07:00 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
with that engine some hard lines and a tranny cooler probably isnt a bad idea either.
Old May 20, 2005 | 04:07 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I was planning to have a 700R4 professionally built.
Old May 20, 2005 | 04:43 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Good plan, my neighbours 8 year old was going to rebuild mine, i mean i just couldnt beat his asking price of a couple fudgecicles and a sugar pop, but letting a professional do it is always another way to go.
Old May 20, 2005 | 05:11 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I was refering to having it BUILT so it could hold 6-700 horse.
Old May 21, 2005 | 01:36 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
I know i was just joking around. I have a very sarcastic sense of humor . And more like 5-600 horse, 700's cant be built any stronger then that
Old May 21, 2005 | 01:58 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Well then its going to be a maybe if it holds since im looking to be about 550 on spray i was wanting some cushion. You know make 550 horse but have a 700 horse tranny. I was really wanting to have overdrive.
Old May 21, 2005 | 10:05 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Someone else on this board really needs to chime in, i really dont know much about the different automatic trannies, but i think your combo is pushing the limits of a 700 built as tough as they come.
Old May 22, 2005 | 10:17 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Shoot Brutalform a pm. He just did this swap with perfect results. Everything was installed, reworked and rewired and he is happy.
Old May 22, 2005 | 08:41 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Getting the wiring for a Lockup converter could be a pain, you will need a new chip for that, unless you wire it up yourself with a switch or something. I think there are also kits available to retrofit a 700R4 to an older car that have their own lockup controls. Man I just swapped my 700 out for a TKO 600 and i couldnt be happier. I think you should stick it out and run the stick, all hotrods should be stick shift in my opinion.
gta90
Sep 15, 2015 04:00 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
