semi-urgent torque converter question
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Ok, this is REALLY pissing me off.
The tranny is a rebuilt 700R4, 27 spline and lockup
First torque converter I bought was a TCI 2600 stall 27 spline non-lockup, which ended up not working because a) summit sent me a 30 spline, and b) i guess ya need a lockup t/c on a lockup tranny, cant use non-lockup
sent that back, and got a killer deal on a slightly used B&M Holeshot 2400 from a guy i talk to fairly often
Anyhow, he had used the t/c on his Monte Carlo, which had a 200R4.......part number on the t/c is 70415 which is for the 200R4/700R4 27 spline lockup
Anyhow, i cant get the torque converter on any further than i was able to get the TCI
the farthest back part of the t/c is level with the bellhousing of the transmission
I've tried turning and pushing, no real "click" and it doesnt go any futher on.
The tranny came with a stock torque converter, which went on all the way with no problem (literally just put it on, give it a little spin and a push, and it went on ALL the way)
Any ideas on what to do? This is the only thing holding me back from getting the car running again
Thanks,
-Chris
Thanks,
-Chris
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Many of the brand ne convertors we've installed required a tapping with a 4lb plastic hammer to help coax it into place. Tolerances are alot tighter with aftermarket convertors than factory stuff, and I've never seen a new one just "slide right on". They've all taken more muscle than what most are used to to set it.
As long as you verify spline count is same, add more muscle and start tapping with a hammer as well when your spinning. Sounds normal to me.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
This is true. To add to it, a newly rebuilt trans will also have a new bushing that the converter slides into. This new bushing snugs things up as well.
well both the converter AND the transmission have a few miles on them.....
not alot, just enough that i dont think it would be just cause its new....
